Old June 3rd, 2020, 10:57   #1
afarfalla
afarfalla's Avatar
Default took out auto flywheel and...
The auto flywheel had a spacer under the bolts, do I install that spacer on the manual flywheel? And body know torque on pressure plate bolts thanks
afarfalla is offline   Reply With Quote
Old June 3rd, 2020, 11:41   #2
PickleRick
PickleRick's Avatar
I did not use the spacer. Also used gasket sealer on all bolts. Flywheel came with bolts and torque specs but i do not recall specs
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old June 3rd, 2020, 12:42   #3
afarfalla
afarfalla's Avatar
60 Nm+90, pressure plate 25Nm. Do you think the spacer was to protect the fly wheel so the bolts would no scuff the metal? and I called you and left a message you answered my question thanks
jetta 2001 auto and 2004 auto - flywheel my d sel TDI 101 9 April 1st, 2019 16:01
Sachs Single mass flywheel kit w/flywheel Vertexboy Private TDI Items for Sale/Wanted 1 December 24th, 2015 07:11
Is a passat 16v Flywheel (037105273c) the right flywheel for a vr6 clutch conversion? dieselmacht VW MKIV-A4 TDIs (VE and PD) 2 December 25th, 2009 05:14
FS: 5 SPD with VR6/G60 Flywheel/Cluth, .681 5th, starter, axles, for Auto/Manual swap CGR Private TDI Items for Sale/Wanted 7 March 9th, 2009 19:23
Auto Trans flywheel need lube? ('05 triptronic) Belt-Squeek Syndrome... steadyhand TDI 101 0 August 26th, 2008 15:58
Page generated in 0.14263 seconds with 13 queries
[Output: 58.02 Kb. compressed to 52.63 Kb. by saving 5.39 Kb. (9.29%)]
