Old May 20th, 2020, 19:23   #1
sanekua
TDI(s): 2003 tdi
Default 2012 Passat Dsg No Communication With Instrument Cluster
Hey everyone, I just got myself a 2012 Passat with a dsg. It ran and drove great until a couple days ago I went to start it and almost all the lights on the instrument cluster came on(steering wheel, check engine, airbag, abs, and esp). I went to crank it and it started and died within 2 seconds. After it did this it cranked and wouldn't t start at all. After about 15 minutes all the lights went away and it started and drove fine. I went to start it again today and it is doing the same thing. The code that I pulled is u0155 lost communication with instrument panel cluster control module. I am wondering if anyone ran Into something similar. I think it's either the can system has a bad wire, or the cluster is dead(but why did it work Intermittently)?
--EuroSwitch, Rear Fogs, W8 Domelight, Euro Badging, GLI Body Kit with Mufflerectomy, WRD Suspension, Euro HIDs, Euro Sport FIS Cluster, Upgraded SMIC, DG Racepipe, Titan 502's, Malone Stage 4 w/EGR Delete,VNT17, Euro MFD Navi
sanekua is offline   Reply With Quote
Old May 20th, 2020, 21:35   #2
joshferrer
joshferrer's Avatar
Have you tried swapping the battery?
I had these similar symptoms a few months ago and it was because my battery was on its way out. I swapped it out for a new battery and everything went away.
I noticed it first with my power steering acting up then one day all of the dash lights came on.
VWs tend to get really weird when the battery starts going out.
-2014 Passat TDI SEL
Malone Stage 2 "Econo" Tune.
Rawtek DPF, EGR, DEF Delete Performance Kit. Straight Pipe. No resonator and no cat.
joshferrer is offline   Reply With Quote
Old May 20th, 2020, 22:00   #3
sanekua
TDI(s): 2003 tdi
It has a brand new battery.
Passat Instrument cluster TonyBee VW MKIII-A3/B4 TDIs 0 October 30th, 2014 23:24
Passat Instrument Cluster andras22 VW MKIII-A3/B4 TDIs 0 October 28th, 2011 10:33
2012 Jetta Instrument cluster question on MPG rotts4u VW MKVI-A6 Jetta Sedan (~ 2011+) 17 August 28th, 2011 13:32
Passat Aftermarket Instrument Cluster 1getbored VW MKIII-A3/B4 TDIs 1 January 18th, 2009 06:50
Passat Instrument Cluster Voltage chuckbrush VW MKIII-A3/B4 TDIs 4 December 23rd, 2003 11:34
Page generated in 0.13262 seconds with 13 queries
[Output: 58.89 Kb. compressed to 53.55 Kb. by saving 5.34 Kb. (9.07%)]
