Old May 7th, 2020, 18:14   #1
matteo2u
Default Injection timing and post intercooler intake temp sensor
Does anyone know if this sensor is used in determining fuel injection timing? Reason I ask is that I am considering drilling and tapping the intercooler right near it to plumb in water/meth injection, but I want to make sure it wouldn’t have an unsafe impact on timing. Ideally, there would be a knock sensor to keep timing in check. Anyone know if there is one of those?
Thanks for any help!
matteo2u is offline   Reply With Quote
Old May 11th, 2020, 09:27   #2
740GLE
What are you trying to gain by adding water meth?
i think EGT sensors are the biggest thing that limits power, so if W/M reduces EGTs you should be good to go.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Post DPF temp sensor, harness location? Help mrbowtieguy VW MKVI-A6 Jetta Sedan (~ 2011+) 0 October 23rd, 2017 14:31
Intake Manifold Temp Sensor Troubleshooting G72 Sensor paulschmid07 VW MKIII-A3/B4 TDIs 2 March 1st, 2016 06:27
Intake Air Temp. Sensor (G42) Manifold Pressure / Boost Sensor (G31) Egroeg VW MKV-A5 Golf/Jettas 0 May 21st, 2015 23:19
Injection Timing Too Advanced or Bad Fuel Temp Sensor ? beartooth91 OBD Scanners 2 June 3rd, 2009 16:00
WTB Connector for intercooler temp sensor P-car Private TDI Items for Sale/Wanted 0 June 18th, 2006 05:27
Page generated in 0.14768 seconds with 13 queries
[Output: 52.81 Kb. compressed to 48.83 Kb. by saving 3.98 Kb. (7.53%)]
