Brian_Spilsbury said:
OK...just to be a Devil's advocate....
WHY should we even waste our money on additives? (snip)
__. You might be right. But it's been shown in rigorous tests and actual use that what additives claim, they do *at least to some extent*.
1) Additives increase cetane slightly. On my sedan, I upped the injection timing advance as far as possible and got nearly 57 MPG overall average over 129K miles. You need a good cetane rating to run advanced timing. And a higher cetane rating is good for smoother starting and cold idling.
2) Water is *bad* for diesels. Additives help handle the small amounts of water that you'll find in any fuel -- and that goes a long way to stop water from building up over time.
3) Our injection systems are lubed by the fuel (I have a VE so I'm more interested in those than the PD but basically they work the same). If you don't get those pieces lubed properly, you'll see wear and these high-pressure components *really* don't like wear.
__. There is a very experienced tribologist who occasionally posts on the board here. He has experiences of fleets who have seen breakdown rates and maintenance costs fall significantly when those fleets went to using additives.
__. The fuel that I can get here in my area is rotgut.
*Some* fuel may be good enough to not need additives but it sure ain't here.
__. I can measure starting times and times when idle smooths out with a stopwatch and see the difference with additives -- no placebo effect there. It's also pretty obvious that the amount of smoke is lower with additives (I use Power Service Silver most of the time) but I'll allow that that hard to measure so maybe that's placebo.
__. It very well may be that the cost of additives exceeds the benefit but the cost is low so it's not a big risk. I think that it's worth it, based on my experience. And if using them prevents an injection pump meltdown it's *way* worth it. I understand that modern fuel is "probably good enough" to not need additives but following that line of thought means that I trust the oil companies (and chain of distribution) to spend the money to make the fuel good quality. I'm not prepared to do that, especially since the cost of "insurance" is so low.
__. I won't say that additives are necessary for everyone but I think they're worth it for me.
