EGR Cooler hoses
kyle_h
Ottawa area, Ontario, Canada
2014 Touareg TDI Execline R-Line
Hi,
does anyone know the rad hose sizes for the EGR cooler heater core hose, as well as the EGR cooler coolant flange hose size?
Would like to remove for "off road use" at some point, wondering what I need for bypass hose.
PS it's a 2010 CJAA common rail...
bobthefarmer
Indianapolis
2006.5 Jetta Mk 5 192K miles; 2012 Car of the Year, Passat Tdi SE+Nav in blue nightgown, shod in 18 inch heels
I would guess 5/8 inch ID. Make sure you get the Coolant type of Hose. Are you going to return it in a bypass loop where the cooler went? Make sure you don't kink it.
