rjdio
I know, might be worthless without pictures, but not really.
Since day one I've had an annoying rattle from the overhead console at about 1200 rpm. So in town - completely would drive you bananas.
Determined it was the LED light housings rattling against the panel. Holding the black LED housings with a finger would stop the rattle.
I removed the overhead console by popping the vented section out with a credit card, then removing the two T-20 torx screws that held-in the middle section with lights and sunroof knob and those darned LEDs. Undid all the harnesses so I could work with the thing on a table. Peeled-off the panel with the LEDs by prying the locking tabs and removing.
The LEDs have about an inch-long black shroud that's attached to nothing - that's what rattles. So I put a two teeeeeeeny drops of super glue on the inside of the panel where the black LED shrouds touch and then reattached it to the housing. Held for 30 seconds. Put everything back together.
Silent as a church on Monday. Unreal what a difference it made. Thought I'd share.
