Guys, come on here, don't start a pissing match because it makes both of you look bad. Yes, you both are right, and yes you both are wrong. A little axial play (a very little) is normal if the cartridge isn't under oil pressure, and a little radial play is normal too: once again, very little. OP, spin the turbo shaft with your fingers and see if it rubs and stops or gives a ting-ting while it is spinning. If it does get a mirror and some sort of light and look at the compressor inlet and see if it is less than shiny or if it shows signs of dragging. If you find either of those then yes there may be something wrong with the turbo's lifespan, but after re-reading this post I am thinking you likely have a boost leak. Very recently I had an odd squealing noise that started happening after 10 PSI of boost and it only got louder with more boost but it did not change pitch; I knew it was a boost leak because I did double-check and pull the pipes off of the turbo to physically inspect it for wear or grinding or oil leaking and it had none. It occurred to me the intake manifold gasket was leaking, and it was; I tightened the loose bolts and the noise went away completely. Just my $0.02
