HELP!!!! 1.6 TDi, starts and dies out!
DMCC
UK
110 TDI MK4
1111111111111111111111111111
Henrick
Ireland
Golf VI TDI, 77 kW (CAYC)
Is the EGR physically blocked? Similar issues arise when EGR is stuck open. Since your is mapped out, sholdn't be a problem but is it blocked ir is just the valve left closed?
Henrick
Ireland
The EGR is on the back of the engine, barely seen from the bottom. You need to look from the tunnel to see it. It's a single assembly which consists of EGR cooler and a valve combined.
Henrick
Ireland
No one knows.
Your car is not stock - it has been tuned and neutered.
These 1.6 TDIs have some problems with injectors - you may be facing an injector issue too.
