jrjackso
Hey,
2000 vw jetta tdi. It's recently been really hot here (30 Celcius + ) and my car wouldn't start. (Temperature may or may not be related.) Kept sounding like it was trying to turn over. On the dash, no glow plug light. I kept trying and finally got the light and got it going - drove it home..
Once I shut it off at home, same problems. I scanned it with VAG-COM and had glow plug code (I get these though b/c I think I have mismatched glow plugs?), and my instrument cluster (#17) was reporting ECM No Communications - Interrmittent. I've never read off the ECM thing, but like I said, glow plug I've seen many times before and it comes back occasionally.
Anyhow, the big symptoms it seems now are: if I get glow plug light, it works. If I don't it doesn't work. And it's intermittent, although leaning towards not starting at all now it seems . Thoughts?
Thanks,
-Jason
As FYI, I've got the ECM out and sitting beside me on my table. The 109 is out as well, beside that. The ecm looks like it's in good condition (inside at least). The connectors are clean, etc. The 109 doesn't look too terrible, but not sure - know what procedure I could use to test the relay?
Thanks,
-Jason
