crazyrunner33
I've had the typical little bit of gear whine upon acceleration ever since I bought the car a couple years ago. Recently, the noise got much louder and is audible on the freeway. It sounds similar to a gear whirl experienced when backing up with certain manual transmissions. Any help or insight on what it could be would be appreciated.
https://youtu.be/Qm7tbkyqSak
It's the higher pitch noise in the first half the video, in the video it sounds like a different engine is running in the background, the lower pitch is the actual engine noise.
Edit: I'm assuming it's toofed, likely a differential bearing or perhaps a thrust bearing. I'll probably pull the transmission once I'm pretty confident it isn't anything outside of the transmission.
Notes for the noise in question:
-it only occurs with acceleration
-on the freeway it is audible when there's load, but disappears when letting off the throttle
-no noticable vibration or performance issue
-the sound is not present at idle
I plan on changing the dsg fluid. Supposedly the previous owner changed it before sale(around 40k ago). I assume it's not a wheel bearing, maybe CV joint or engine mount? Alternator pulley and tensioner were recently replaced, I assume that would make noise without load.
The sound it started making on the freeway is similar to this guy's video:
https://youtu.be/HGfPmStl7cE
