Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old June 7th, 2019, 17:00   #1
ErackTDI
Default scangauge2 help
hey so i purchased a scan gauge 2 used
and it is stuck at the connecting screen
i have tried different protocols to get it to connect
has anyone had this issue and found a solution?
ErackTDI is offline   Reply With Quote
Old June 7th, 2019, 17:52   #2
Vince Waldon
Vince Waldon's Avatar
Is your engine running?
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old June 8th, 2019, 10:24   #3
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
1,) Download the users manual if you haven't done so already.
2.) It does take a bit of time to "Connect"
3.) Any bent or missing pins in the OBD II port or the Scangauge plug?
4.) Maybe that's why it got sold ??
There are no "protocols" to change as far as I know, so what you've done there is beyond my understanding.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.Scangauge II
Jetta_Pilot is offline   Reply With Quote
Old June 10th, 2019, 15:45   #4
ErackTDI
so it works fine in my 2013 jetta but won't connect to my 04
tried with engine running and not and tried forcing iso as thats what they told me is the right one for my car
Old June 10th, 2019, 18:43   #5
Vince Waldon
Ok, next step might be to see if *anything* can connect to the OBD2 port in your 04... do you have access to a scanner?
Old June 11th, 2019, 10:13   #6
imo000
imo000's Avatar
Fuel Economy: Good enough
I had this problem, contacted the manufacturer but they refused to help.
imo000 is offline   Reply With Quote
Old June 11th, 2019, 16:55   #7
P2B
P2B's Avatar
I had this problem with a new SGII today.
Connected fine out of the box, ran through setup, then disconnected it so I could route the cable behind the dash. Reconnected it, stuck at the connecting screen. Tried a few times, same thing.
I then disconnected it from the OBDII port, waited 10minutes, tried again and it connected immediately. My theory is that plugging in the RJ45 while the OBDII has power can hang the SGII.
Probably not the OP's problem but might help someone.
Simon
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is online now   Reply With Quote
Old June 12th, 2019, 06:04   #8
ErackTDI
so my launch scanner works my mpps flash cable works vcds works odis works
i have contacted scangauge they said to send it in for update and they will do the update and whatever repairs are necessary at the same time
Old June 12th, 2019, 06:20   #9
imo000
imo000's Avatar
Send it in on their dime or yours?
Old June 12th, 2019, 06:37   #10
ErackTDI
i am paying for shipping to them
and the upgrade fee
they are paying return and said they are covering any parts necessary to repair it
ScanGauge2 for sale Jagerbecher Private TDI Items for Sale/Wanted 4 January 6th, 2016 06:50
scangauge2 won't connect greenskeeper OBD Scanners 7 April 23rd, 2012 17:59
ScanGauge2 coasting vAtO OBD Scanners 9 October 15th, 2011 22:21
Scangauge2/Autometer Gauges questions ss04vv OBD Scanners 5 October 5th, 2011 16:45
bad mileage on scangauge2 upsguy OBD Scanners 14 September 22nd, 2007 10:33
Page generated in 0.15114 seconds with 11 queries
[Output: 96.11 Kb. compressed to 81.53 Kb. by saving 14.58 Kb. (15.17%)]
