lamboworld
I pulled the following codes today. Can someone give me some advice on how to resolve these codes. My check engine light came on earlier today. Thanks.
Friday,13,May,2016,21:32:01:26998
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 03G 906 016 AB HW: 028 101 223 8
Component and/or Version: R4 1,9L EDC G000SG 7550
Software Coding: 0050071
Work Shop Code: WSC 00066 000 00000
VCID: 63EB5ABBA23CCE2603-8036
3 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368785 km
Time Indication: 0
Date: 2000.00.00
Time: 05:43:31
Freeze Frame:
RPM: 1785 /min
Speed: 63.0 km/h
Load: 51.4 %
Voltage: 13.76 V
Mass Air / Rev.: 700.0 mg/str
Duty Cycle: 95.1 %
Bin. Bits: 00000000
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368973 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:33
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Bin. Bits: 00001100
Temperature: 20.7°C
Bin. Bits: 10110000
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368973 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:47
Freeze Frame:
RPM: 819 /min
Speed: 3.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001100
Temperature: 21.6°C
Bin. Bits: 10110000
www.Ross-Tech.com
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368785 km
Time Indication: 0
Date: 2000.00.00
Time: 05:43:31
Freeze Frame:
RPM: 1785 /min
Speed: 63.0 km/h
Load: 51.4 %
Voltage: 13.76 V
Duty Cycle: 95.1 %
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368973 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:33
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Bin. Bits: 00001100
Temperature: 20.7°C
Bin. Bits: 10110000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 368973 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:47
Freeze Frame:
RPM: 819 /min
Speed: 3.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001100
Temperature: 21.6°C
Bin. Bits: 10110000
