rock4xfab
What causes the rpm to spike like you put the gas pedal to wide open throttle. I had to shut the car down let sit restart and limp it home.. all this after the new turbo was installed
I pulled the tube at the intake which was bone dry before I started and it was oil filmed... im sure the brand new intercooler is full also. And I am guessing the new turbo was **** from the get go. This is starting to get expensive and I am fricking tired cleaning diesel oil coated crap.So, maybe the new turbo's bad. Check the intercooler, see if it's full of oil.
The turbo should have oil in it, they need primed after new install. The compressor vane shaft bearings need lubricated on start up. It takes time for the oil feed line to deliver oil to the shaft bearings. Maybe the return line was damaged and there was blockage preventing flow. You didn't do a home rebuild on it I hope. Those e-bay kits are made in China, and a turbo needs balanced after the compressor bearings are replaced. The compressor is spun at high speed and any balance variations are measured and the vanes are trimmed or clipped to remove the imbalances until the compressor's orbit is completely concentric. This prevents premature bearing failure. Spending that 800.00 to ID Parts is worth it.I pulled the tube at the intake which was bone dry before I started and it was oil filmed... im sure the brand new intercooler is full also. And I am guessing the new turbo was **** from the get go. This is starting to get expensive and I am fricking tired cleaning diesel oil coated crap.
The turbo was filled with oil before I installed it. I also primed it. No I did not get it from (proth) it is a US mfg XS turbo charger out Ohio. The return lines and feed line are brand new.The return is an OEM replacment, the supply line is a SS flex with-AN #3 fitting and 12 mm banjo. The turbo is NOT CHINEASE. The engine was turned over and pressure built up before I started the motor.The turbo should have oil in it, they need primed after new install. The compressor vane shaft bearings need lubricated on start up. It takes time for the oil feed line to deliver oil to the shaft bearings. Maybe the return line was damaged and there was blockage preventing flow.
New or rebuilt?...it is a US mfg XS turbo charger out Ohio...
What?...The engine was turned over and pressure built up before I started the motor.
I built pressure up before I started. Cycled the key so oil pump could build pressure..New or rebuilt?
What?
Sounds like you did everything right.
Before you do anymore, you should now check compression to rule out bent rods. Very common after ingesting oil and running away. If you don't, you risk a rod failing months down the road and punching a hole through the block.
Hate to say it but, I would suspect your reman turbo. There is a reason they are not highly recommended on this site. Get your money back, buy a new turbo from a trusted vendor, drain your intercooler and try again.
Not being a smartass. Sounds like the turbo was bad. I'm wondering about the vendor. My neighbor had a runaway after he did a manifold cleaning. I did mine once and did the VCDS off road setting. Haven't touched it since. If the turbo failed it was oil flowing around the compressor shaft bearings and into the IC pipe. My neighbors 1.9 was trashed, bent rods and a hole in a piston after his runaway. Oil pump is mechanical not a pressure start diesel. Good luck, I hope. I defiantly be calling the vendor. They will ask about how it was installed. I see they sell remans. They seem rather cheap.The turbo was filled with oil before I installed it. I also primed it. No I did not get it from (proth) it is a US mfg XS turbo charger out Ohio. The return lines and feed line are brand new.The return is an OEM replacment, the supply line is a SS flex with-AN #3 fitting and 12 mm banjo. The turbo is NOT CHINEASE. The engine was turned over and pressure built up before I started the motor.
I'd call vendor for sure. But Vince is right if you could shut it off with the key you didn't have a complete runaway.I am not sure how a compression test rules out anything with rods,valves maybe but rods... that does not make any sence. As for the turbo, i keep hearing about remans no good and bearings. Their are no bearings just a bronze bushing that the turbine floats in thin layer of oil...I am going to go back through it make sure I did nothing to cause this. But if you saw my original thread I had questions about the turbo that the company told me was normal, and im not so sure now.
if the anti-shudder did it's job, it would of starved the engine of air.Did you "shut it down" by turning off the key, or stalling it with the clutch?
If it turned off with the key it was NOT a turbo-induced runaway.
Not so, my neighbors roared through about 4 quarts of oil. His was on the street a half block from his house. He put it in neutral and turned the key off. Yes he was in second gear and couldn't stall it. Somebody called the fire department. Whitbred put in his new used engine, out of a Beetle TDI. The anti-shudder valve is useless. I know their supposed to prevent runaway, but they don't.if the anti-shudder did it's job, it would of starved the engine of air.
I would call them. I'm from Ohio, but I checked out their site. Their cheap, bad sign there. Sell remans bad sign. Garret doesn't have a reman kit for the VNTs do to imbalance problems with the compressors and liability issues. The machine to balance turbos is very expensive. I see what you could get back from them. I'm not being b&^tch, but a turbo shouldn't be a place to start saving money. Good vendor, ID parts.When I first turned the key off it kept running... I turned it back on then off and it shut down.....I just got everything back off the car. Intake has a light coating of oil..turbo does not appear to have anymore play but the exhaust side is burnt black build up... I will be calling the vendor tomorrow when they open btw its an automatic not a stick
About the correct price for a new one. The vendors on this site are safe. I'm from Ohio and I believe the one in this thread was purchased from a place in Saint Lawrence, Ohio. I saw their web site, just as cheap as Proth. I'd be calling them and getting some money back.
The one in question is from here.Just pointing out another great vendor who supports this website. The Torque Junkie is TdiRacing on these forums.
