LNXGUY
Wow man, that's some awesome work!
Interesting way to monitor engine load.I tuned my previous setup to cruise just under 30:1 AFR and WOT at 17:1 AFR. I'm not sure I'll be able to get it down to 30:1 cruising
ah thought you might made those too...the EMP adapter is cake, the double banjo is pretty cool though, I need to find a latheI didn't make the AN banjo fittings, found them on Ebay. I made the double banjo bolt and the EMP adapter
An AFR that is around 17:1 is going to be right around full engine load, as that is where it is getting as much fuel as it can burn and is therefore putting out as much power as it can.I'm not sure its going to monitor load all that well,
Well, 10% of the engine's peak maximum rated output at least.You can have a 17:1 AFR at 10% engine load if you don't have the mass airflow to go with it.
I don't even know what the numbers of mine are, it'll swing a 10" chuck with very little room to spare for the jaws to protrude out.Lathe is also a Jet, 1340PB, I actually used a nice Hardinge for these parts. My jet has a ton of slop but I can still make good parts on it
