Rather Be Biking
Just went to the dealer and had them replace exhaust flap motor under warranty. On the way home, according to VCDS, the car threw the following code (but no check engine light). Did they mess something up? Should I ignore it? Why isn't the CEL on?
Thanks!
1 Fault Found:
000310 - Oxygen (Lambda) Sensor B1 S2: Malfunction in Circuit
P0136 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 42885 km
Time Indication: 0
Date: 2000.00.00
Time: 12:43:41
Freeze Frame:
RPM: 1955 /min
Speed: 103.0 km/h
Lambda: 30.8 %
Mass Air / Rev.: 335.0 mg/str
Voltage: 0.000 V
(no units): 0.01
Voltage: 0.975 V
Readiness: 0 0 0 0 0
Thanks!
1 Fault Found:
P0136 - 000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 42885 km
Time Indication: 0
Date: 2000.00.00
Time: 12:43:41
Freeze Frame:
RPM: 1955 /min
Speed: 103.0 km/h
Lambda: 30.8 %
Voltage: 0.000 V
(no units): 0.01
Voltage: 0.975 V
