powerram250
Put new batteries in it and tried many ways to reprogram it. Oreilly auto parts tester says it works. Any special way to reprogram it? It's a 1998 VW Jetta.
1997-1999 MK3powerram250 said:Put new batteries in it and tried many ways to reprogram it. Oreilly auto parts tester says it works. Any special way to reprogram it? It's a 1998 VW Jetta.
jetta said:1997-1999 MK3
__________
It will need 2 keys.
**-Turn ignition ON
-Close all doors and trunk
-Take 2 key and turn lock cyl.on dr. door to unlock position and hold till horn make some sound and relese key(3 times horn sould sound)
-Press ulock button on first transmitter (alarm horn will sound once)
-Press ulock button on second transitter(alarm horn will sound twice)
-Repeat same for 3&4 transitter
-Turn lock cyl.on dr. door to unlock position and hold till horn make some sound and relese key(3 times horn sould sound)
-Switch ignition off
Per Bentley, you need 2 keys. You have one minute to complete the procedure (I don't why, it just saids so --- maybe the car explodes, maybe a kitten dies somewhere). Insert one key in the ignition to the on position and the other key in the driver's door lock. Lock the door then unlock it till you hear the horn beep three times; then hit the unlock on the remote; horn beeps one more time. Remove keys, donepowerram250 said:Put new batteries in it and tried many ways to reprogram it. Oreilly auto parts tester says it works. Any special way to reprogram it? It's a 1998 VW Jetta.
