South Bend Stage 3, SMF version, rated to hold 425 ft-lbs (
not ft/lbs or lbs/ft) is a good way to go. TDIparts has the SBC 3 SMF clutch.
The decision to upgrade will be an easy one....you definitely WILL need a clutch upgrade with RC3 tuning and PP520 nozzles. You'll eventually WANT to do the upgrade and do it sooner than planned to be able to take full advantage of the tuning and nozzle upgrade. The TORQUE is addictive.
The SBC 3 is waaaay better than the G60/VR6 clutch and uses the same (G60) SMF. I have the G60/VR6 clutch in my 02 Golf and it's held up fine for my mods until I went to RC4b tuning and a VNT-17 turbo upgrade. Now I can easily make the VR6 easily slip in 4th and 5th. I'm not surprised since I'm right at the edge of its rating (~ 300-330 ft-lbs) and I've already got 190k miles of modded performance on it. It's probably about due for a new clutch anyway. It will last for a while provided I'm kind to it.
An important lesson many of us on TDIclub have learned is to get a clutch that's way stronger than you'll ever need now and in the future, taking into account future mod plans plus allow some headroom for de-rating for long life. Clutch jobs are hard and expensive and not fun on these cars and you don't want to do a clutch upgrade more than once if you can help it. Many of us upgraded our clutches after performance mods because of slippage, then did more mods and then later faced having to upgrade the clutch AGAIN because of slippage. Best to do a clutch upgrade only once and be done with it. I went with the G60/VR6 upgrade because it was a popular and recommended upgrade at the time. I've done more mods since the upgrade and I'm now facing having to upgrade the clutch AGAIN because of my mods. I would have been better off to have put a stronger clutch in the first time around. A South Bend Stage 3 SMF upgrade is what I'm going with when I eventually have to change the clutch. The good news is a lot has been learned over the years about modding our TDIs and the mods are becoming more refined and making the cars a lot faster than they were a few years ago.
Good luck.
