I was wondering if anybody had the wiring schematic for a 2001 volkswagen jetta tdi. I'm doing a swap and the mechanical work doesn't bother me. The electrical things would be allot easier if I knew which wires I need to tap into and remove. I have a whole donor car everything there I'm just going to pull the engine and transmission out together. Because the engine on the automatic had a timing belt failure and no longer useable. Thanks in advance
