chris.howard713
Just read through this post I am having similar issues with my 09 Jetta TDI. I recently purchased the Vagcom and already fixed one issue on my 98 Golf VR6 now to fix my 09 TDI. Below is the faults from my vagcom reading. Here is a brief explanation of what I am seeing my CEL stays on and as long as I go I have no issues (already replaced the turbo boost position sensor). When the car drops down to approx 1200-1400 RPMs (like clock work) the glow plug light comes on and I get the Engine fault workshop on the display and I lose turbo. I can throw it in neutral turn the car off and back on and everything is good until RPMs drop again. First thing tomorrow I am going to try the vacuum test but thought I would see if anything new has come up since the last post in Oct.
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: --H01--- Serial number: VWX7Z0H424M0Z8
Coding: 0050078
Shop #: WSC 20158 444 98171
VCID: 3F8770986E669DB
2 Faults Found:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 14
Mileage: 148361 km
Time Indication: 0
Date: 2000.00.00
Time: 00:12:26
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Voltage: 13.98 V
Temperature: 156.0°C
Lambda: -30.0 %
Bin. Bits: 00001110
Voltage: 2.052 V
000175 - Actuator Module for Turbocharger 1
P00AF - 000 - Stuck - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 13
Mileage: 148361 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:31
Freeze Frame:
RPM: 851 /min
Speed: 6.0 km/h
Load: 19.6 %
Load: 98.8 %
Lambda: 41.8 %
Absolute Pres.: 785.4 mbar
Temperature: 23.4°C
Readiness: 1 2 0 0 0
Coding: 0050078
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Mileage: 148361 km
Time Indication: 0
Date: 2000.00.00
Time: 00:12:26
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Voltage: 13.98 V
Lambda: -30.0 %
Bin. Bits: 00001110
Voltage: 2.052 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Mileage: 148361 km
Time Indication: 0
Date: 2000.00.00
Time: 00:17:31
Freeze Frame:
RPM: 851 /min
Speed: 6.0 km/h
Load: 19.6 %
Load: 98.8 %
Lambda: 41.8 %
Temperature: 23.4°C
