How bad is the smell after DPF delete?
TurboJay
Montreal,Canada
2011 Golf
Hey guys!
I have owned the golf for more than 2 years now and i really like it so far, except for the regen ( i hardly drive more than 30km a day now) and for the last 8 months I keep having CEL codes for the emission system. I have been to the dealership at least 2times/months since last summer and it's getting old real fast..
I'd like to do a dpf/egr delete, but i am wondering how bad is the smell afterwards? I plan on installing a catted downpipe.. but if its going to smell awful, i'd rather sell the car ..
Thunder Chicken
Sioux Lookout, Ontario
2012 Golf Wagon
while I don't have a Cat on mine (deleted).... i'd say she'll have the classic diesel car smell. I don't mind it. It smells like a diesel.. a puff of blue smoke on cold mornings, and when someone is tailgating, drop a few gears, put the pedal to the floor and lug it hard, it must make a bit of stink cause most people back off.
Being in Montreal, you can get an awesome pipe from Rawtek and a tune easy enough from many places. The cruze down hwy 40 through the city will be so much funner.
JELLOWSUBMARINE
yes
Smell? Thats anti Prius spray
MikeH31324
SE Georgia USA
2012 Golf TDI 2 door 6MT
My old Dodge truck powered by a Cummins 5.9 makes LOTS of Prius repellent if the RPM is low and you push the throttle to the floor. I accidentally filled the inside of a Tesla with Prius repellent a few weeks ago. Did not realize it until it was too late that the old dude had the window down. My bad.....
iamatt
Rosharon, Texas
2014 Jetta 6 Speed manual
Not a problem at.all. Sure beats that nasty cat dpf regen smell.
Sent from my Pixel 3 using Tapatalk
iamatt
Rosharon, Texas
So it's not as bad as the regen smell? If it only smell diesel a little bit, I can live with it i guess!
You have a diesel so yeah if you remove the emissions things you will smell a little diesel smoke. It's way better then having to drop it off at dealership due to problems caused by running with it in tact. You'll be fine.
JELLOWSUBMARINE
yes
It may reek havok with common rail system (?), but without the DPF a little WVO will give it a nice french fry smell;)
oilhammer
outside St Louis, MO
I honestly wish there was a good option for a nice sized one-way catalyst for deleted CRs. Because with nothing at all, they smell worse than a stock VE does. Even with a low output tune, that doesn't really smoke except for a very minor amount on a floorboard acceleration, there is still a smell.
You don't notice it inside the car of course, but I can smell it after I get out of the car, and you can stink the shop up driving in and out if you are not quick about it.
dlhovland
Yakima
2015 golf Tdi manual transmission. Wife's car a 2014 toured v6 Tdi
Rawtek sells a mid pipe with a cat in it. I have one one 2013 JSW
turbobrick240
maine
It's definitely a more acrid diesel smell than the diesel trucks and tractors I grew up with. Probably due to the increased NOx/higher cylinder pressures.
Geordi
Somewhere between Heaven and Hell. But it is reall
14 JSW DSG, 03 Wagon 01M, 400k and IPT performance auto!
I thought I would care about the smell or that it would be an issue so initially I left the second cat in place instead of using the full Rawtek pipe. I actually went a bit custom and bought a set of the v-band rings and welded the pipe so that I could keep that cat or swap the straight pipe in instead of the cat...
The smell actually isn't that bad. I use my TDI for "car camping" with the engine idling all night and there's no issues. The engine is running great with a Malone tune, although I probably should get the transmission tune one of these days. When you lay into it, sometimes the transmission feels like it skips a shift - that's actually the computer cutting the power b/c it is above the threshold of the trans tune.
ihatespeed
holbrook, ma
11 tdi wagon 6mt 15 golf 6mt (Wife's) 2000 Ford 350 7.3l 6mt 4x4 (technically a TDI)
This is my second Malone stage 2 JSW, first had a performance diesel exhaust (no longer around afaik, guy was out of Burlington, top notch service), resonator, no muffler, it was fine, bit of smell when cold, you might notice it in traffic or backing up with the windows down, I did not mind it, my wife occasionally complained. I did get a few more questions about the noise level than I really wanted while getting my inspection, "is that a leak or a cat back?" So the second time round I have the buzken exhaust, mufler no resonator, initially with no catalyst, its near stock noise, but maybe a hint of turbo. Smell didn't bother me, but My Wife is picky about chemical / exhaust smells, she can spend all week with a filthy horse blanket in her car, but if I open a can of MEK in the next county she's asking what I'm doing lol. anyways I got a 2.5" diesel catalyst from ID parts, its definitely cutting the smoke and smell, slightly quieter and wife only occasionally mentions the smell, but I still get to enjoy my tune. and she does not seem to show preference over my 202k tuned '11 vs her 60k stock '15 when we go places together.
Owain@malonetuning
Associate Vendor , w/Business number
Vancouver
PD jetta wagon
The 2L and 3L VWs are fine since they have good catalysts. I'd keep the primary cat (pre dpf) on the 3L. If modding a 2L you can keep everything else on the exhaust stock and it'll run cleaner than a factory PD. Ran one of our dev cars like that for years and it's still kicking, cat has not clogged and it smells much less than a fully deleted car.
dlhovland
Yakima
Awesome! How is the smell? The fit?
Far less smell when the cat gets up to temp much better. I is a high flow cat. When cold has diesel smell. Perfect fit when mated up to the rest of Malone system.
KamloopsDan
British Columbia
2013 Golf Wagon TDI
I have a 2013 Golf and had a Rawtek DPF delete (straight pipe eco kit) installed the other week.
I came home from the install and backed my car into my garage and could still smell diesel after 3-4hrs of it sitting idle.
In my opinion, the smell is very noticeable if the car is garaged. If it's parked outside, who cares.
97B4TDi
Wisconsin
1997 B4 Passat, 2013 Jetta Sportwagen TDI
A resonator and high flow cat leaves you with some smell after a cold start but once it warms up there is no noticeable smell.
dlhovland
Yakima
I currently have your system stage 3 on 2013 JSW. With cat. If I wanted to clean up th smell some more would have to install nox cat and sulfur cat? What about the exhaust flap? Thanks David H
LibertyHog1
Central, IL
2014 Jetta TDI, 6MT
I'm curious if anyone else has a strong "school bus" diesel smell even when cruising at highway/interstate speeds with the windows down?
I did a buzzken delete and expected a smell out of the tailpipe and in the car when stopped or idling with windows down.
But I still get the diesel and NOx smell while cruising?
Naturally I checked for leaks on the nee exhaust to no avail. Retorqued the v-band clamp... tried reseating all connection points... added copper RTV sealant to sealing surfaces.
Marginal improvement at best.
I did have the EGR line to the intake crack and start leaking so I took that whole thing out (P.I.T.A.) and put the block-off plate on the exhaust manifold... same as above.
So is anyone else experiencing this or do I have a leak? I'm not nose sensitive so I doubt it's just me being abnormally sensitive.
roadlust
Yakima, Washington
2003 golf gl reflex silver (sold) 2013 TDI 2 door Golf Blue Graphite Metallic 6MT Premium Package.
Is there more noise coming from the engine (not exhaust) than before?
LibertyHog1
Central, IL
2014 Jetta TDI, 6MT
Not anymore.
There was a noise that developed after a week or so that I was able to pinpoint to a crack in the EGR tube that runs from the exhaust manifold to the intake.
Noise disappeared after I pulled that EGR pipe and moves the block-off plate to where the pipe bolted to the exhaust manifold (should have done it that way on the initial install. But I digress).
I've tried listening and feeling for leaks since then to no avail
Thunder Chicken
2012 Golf Wagon
Not anymore.
Check your rear hatch seal or rear door seals as the exhaust smell will come in around the hatch. My hatch is so rusted out that it leaks water around the brake light and washer arm.
Invig
Adelaide
Mk5 Jetta BKD
I know this is an old post but figured I’d throw my two cents.. I just deleted my mk6 tdi I work as a diesel mechanic and did my delete on the weekend. I was blown away at how much that little diesel smells lol old mechanical big cam Cummins and 3406b Cats don’t smell that bad even modern diesels deleted.. probably how how the exhaust is lol
This is my concern getting an EGR delete
Twitchytoes
United States
2014 NMS Passat TDI SE - 2.0L CKRA
Necro! Just want to ask some clarification on this... For the 2L, do you mean delete the cat & DPF combo, keep the 2 downstream cats?
Porch
Asheville, NC
2011 jetta sportwagen tdi 6spd
I did a full delete and added a high flow cat, which does nothing, and it smells ridiculous. Comes right in through the hatch, can't drive slow with the windows down, it's awful. Everyone here who says otherwise is lying. "Smells like a candle, only at idle", and other such nonsense. Might sell mine on here soon after I pay it off. Drives great...
oilhammer
Something must be wrong with yours, I drive these all the time and never notice it like that. You probably have a leak somewhere.
