Old April 12th, 2012, 11:55   #1
HRC-E.B.
Default Hesitation or Surging CR140
Has anyone experienced hesitation/surging issue with their CR 2.0 TDI (140).
I didn't notice that with mine initially, but it seems to occur somewhat often now, if I happen to drive at more or less constant speed in 3rd gear at anywhere between 1700-2200 rpm or accelerate smoothly at part throttle from those revs, the car would either respond erratically to throttle input or there is a sort of hesitation or a bit of surging when I keep the throttle steady at part throttle.
Is this normal or a symptom of any problems? The car is still fairly new (2012) with about 4000 miles on it, manual transmission.
HRC-E.B. is offline   Reply With Quote
Old April 23rd, 2012, 21:23   #2
jimsiders
I have a 2012 MKVI also, and I've also noticed some surging at certain throttle positions in third gear.
I've been chalking it up to the engine computer trying to figure out whether I'm about to accelerate (based on RPM, throttle position, and speed) and starting to spin up the turbo in advance based on its prediction.
I also have a hunch that the gear ratio chosen by the designers for third gear in our cars can contribute to this: I find myself solidly in the max torque RPM range pretty much all the time when I'm using Third, so it's easy for a tiny movement of the throttle to get the turbo involved.
Maybe I'm just trying to pretend there isn't an issue with my turbo? :-/
jim
jimsiders is offline   Reply With Quote
Old April 24th, 2012, 06:11   #3
Elfnmagik
Elfnmagik's Avatar
Do a search.
HPFP, DSG, DPF, DMF...I hate acronyms!
Elfnmagik is offline   Reply With Quote
CR140 Power: Round One storx TDI Power Enhancements 66 August 23rd, 2014 15:45
Hesitation/Surging HRC-E.B. TDI Power Enhancements 2 March 14th, 2013 11:01
"Surging" "lurching" or shift hesitation FeelingMN Audi A3 11 March 26th, 2012 00:07
Did my MAF go bad?-hesitation/surging symptoms digdug TDI 101 3 April 30th, 2008 09:32
Pictures of the CR140, enjoy... bhtooefr General VW Discussion 8 January 28th, 2008 06:57
Page generated in 0.14154 seconds with 11 queries
[Output: 57.22 Kb. compressed to 51.97 Kb. by saving 5.25 Kb. (9.18%)]
