Old September 15th, 2009, 18:35   #91
geezerb
Fuel Economy: City/Highway combined
Default 2009 TDI-specific issues
Thank you for the reply,kindly DRDAWG. That price is sure an indication that there are few,if any, free lunches anymore. Back in the day (about 2 years ago) I wailed about having to drop ahout $80 on a whole set. Ah, them were the days!!
geezerb is offline   Reply With Quote
Old September 18th, 2009, 17:52   #92
krsone
Originally Posted by krsone
So I've looked around the forums for some mention of this but haven't found anything: Is the EGR modification/calibration necessary for the new 2009s? If so, how soon are you supposed to get this done before it does permanent damage?
Thanks!
^^Does anyone know the answer to my question that I asked a couple weeks ago?
krsone is offline   Reply With Quote
Old September 18th, 2009, 17:57   #93
Turbine Suburban
No, no modification is warranted, the DPF is a fickle and very costly creature best tended to by mother VDUB. Screw it up by somehow remapping things, and you may be out 3 or 4 large.
Turbine Suburban is offline   Reply With Quote
Old September 18th, 2009, 19:20   #94
Jack Frost
Jack Frost's Avatar
Even VW is reluctant to modify anything. DSG shift programming for example.
2009 TDI, Spice Red with Black Interior, DSG, Purelli Winter Tires, VW Block Heater
1996 Suburu Legacy (wife)
John Deere 2130 Diesel Tractor
1989 Ford Mustang 5.0 (gone but not forgotton)
Jack Frost is offline   Reply With Quote
Old September 19th, 2009, 07:10   #95
DoctorDawg
DoctorDawg's Avatar
In a way, I suppose a more general version of this question (i.e., "Can/should I modify the X?") should qualify as a FAQ here and get added to the list in post #1. The reasons I hesitate to do so are: (1) These cars are too new for anyone to have any solid, fact-based answers, and (2) My own personal answer is merely my opinion and doesn't deserve to end up sounding like a fact.
In case you're curious though, my own personal opinion is this: The '09+ design is so highly computerized, bristling with so many kinds of sensors we've never seen before (just one example: pressure-sensing glow plugs), all of which the ECU relies upon to make its decisions, there's a very high probability that any engine or drivetrain mods will have effects on ECU inputs that will deeply confuse your computer, throw a bunch of codes, and perhaps cause Very Bad Things to happen. As a rule of thumb, this is not a car suitable for modding, except for trivial stuff like adding a skidplate. For more functional types of mods proceed at your own risk (and, of course, kiss your warranty goodbye!). If one accepts this argument, it then follows that no modifications are "necessary".
2009 Jetta TDI (Loyal Edition, Campi White, DSG, #1470, built 5/08): 56K miles and zero problems 1/16/2011.
WeatherTech deflectors, Dieselgeek skid plate (both A+)
My other diesel gets 120 MPG (minutes per gallon): Kubota 2630 w/ FEL
My other other diesel I don't even want to talk about (1995 Dodge Ram 2500 Cummins 4x4)
DoctorDawg is offline   Reply With Quote
Old September 20th, 2009, 19:13   #96
krsone
Thanks for all the input guys...I wasn't sure if this new engine is expected to have the same issues with clogging of the intake system over a long period of time like the older engines do. I suppose this new high tech engine is both a blessing and a curse, depending on what you want to do with it.
2009 Jetta TDI, blue graphite, manual, bluetooth
Old November 7th, 2009, 10:23   #97
6910sb
6910sb's Avatar
TDI(s): 2010 JSW
Default New question to continue thread
Great thread. Here's a question to keep it alive.
Why won't my '10 JSW rev to redline? I'm trying to use the entire powerband as suggested in the break-in procedures, and the engine only revs to 4200.
Jeff
2010 Blue Graphite JSW TDI, DSG, Pano, Portos.
6910sb is offline   Reply With Quote
Old November 7th, 2009, 12:50   #98
funoutdoors121
TDI(s): 15 GSW S 6MT
My guess only: you've got a DSG => it will shift for you prior to getting to high revs/red line...?
2009 JSW TDI, silver, 6 speed- sold back to VW on 6/13/17
2015 GSW TDI, S, dark grey, 6 speed
VCDS available
funoutdoors121 is offline   Reply With Quote
Old November 7th, 2009, 16:17   #99
DoctorDawg
DoctorDawg's Avatar
Have you tried to redline it in Sport mode?
Old November 7th, 2009, 19:33   #100
6910sb
6910sb's Avatar
TDI(s): 2010 JSW
I forgot to mention that I tried all modes including manual. I got the numbers wrong also, it'll rev to 4400, not 4200.
Jeff
Old November 8th, 2009, 19:03   #101
DASTDI
DASTDI's Avatar
TDI(s): 2010 Sedan
All,
Yes, I have the same scenario. I like the transmission, but it does shift too early for my preference. I thought I may need the firmware/software upgrade, but my mfg date is August 2009.
DASTDI is offline   Reply With Quote
Old November 8th, 2009, 22:52   #102
GTIDan
GTIDan's Avatar
Max hp is at 4,200...........why go more?
9/02/09 Build date.
GTIDan is offline   Reply With Quote
Old November 9th, 2009, 06:23   #103
Elfnmagik
Elfnmagik's Avatar
Max hp is 4,200
That's the Banks version.
HPFP, DSG, DPF, DMF...I hate acronyms!
Elfnmagik is offline   Reply With Quote
Old November 9th, 2009, 06:27   #104
Elfnmagik
Elfnmagik's Avatar
It won't matter which shift mode you have it in.
Take the car out, get started rolling at around 30 mph, stick it hard to the floor and hold it. If it shifts at or near 4500 you're fine. Just remember to really bury the pedal. I think there's a 'kick-down' switch at the the carpet.
Old November 9th, 2009, 22:08   #105
soldierguy
Originally Posted by securityguy
The sensors are wireless transmitters that have small lithium batteries in them that last 5-7 years. They transmit a radio signal to the cars computer which decodes it into a PSI reading and compares that reading to a base line value. If less than the base line, it triggers a "low air" indication on your dashboard.
When the battery dies, you buy a new sensor as they do NOT have user serviceable parts. Sensors can be bought on eBay or vwwvortex. Cost around $80 - $100.
Older post, I know. But I was looking at the owner's manual on my 2010 Golf, and it says that the TPMS sensors should be replaced at 6 years regardless of mileage, per the service schedule. So you're right on the money with your 5-7 years recommendation.
Soldierguy the SuperCommuter
'15 Jetta TDI S DSG
soldierguy is offline   Reply With Quote
Page generated in 0.18803 seconds with 10 queries
[Output: 126.28 Kb. compressed to 104.44 Kb. by saving 21.84 Kb. (17.29%)]
