Old November 10th, 2007, 10:10   #1
VelvetFoot
VelvetFoot's Avatar
Default How to Change ECM for Rocketchip
Hi all. I can't find the directions for my Rocketchip switchable ECM (2 and 3.1). Would anybody have the directions to switch the ECMs and activate the two programs? It's at 2000 TDI Beetle.
Thanks.
Still lovin' my 2000 TDI Beetle!
VelvetFoot is offline   Reply With Quote
Old November 11th, 2007, 13:16   #2
danix
danix's Avatar
This was recently posted as I recall, try a search.
danix is offline   Reply With Quote
Old November 11th, 2007, 23:23   #3
onehotspud
onehotspud's Avatar
Fuel Economy: 59/45/36
Using VAG-COM
1. Goto Engine
2. Goto Adaption
3. Change to either 00001 or 00002 (depending on your programing)
4. Do-It
5. Close controller
6. Cycle key off, then on (resets ECM)
7. Go back in and make sure that the programing has changed.
For me, #00001 is RC2, #00002 is RC3. Your programing may differ.
2001 Jetta TDI, Sprint 520s, RocketChip Stage III, G60 Flywheel & VR6 Clutch, Boost Gauge, DIY Boostvalve
Dieselgeek Shortshifter, Low Pixel Gasser MFA, VAG-COM (best tool & support ever), ECodes w/motors, SRP
ASR Retrofit.
A few steps closer to a CoolWht clone...
onehotspud is offline   Reply With Quote
Old November 12th, 2007, 07:18   #4
VelvetFoot
VelvetFoot's Avatar
Thanks. I thought there was something additional for changing ECMs. I look on the Bentley CD, if it still works.
Old November 12th, 2007, 07:21   #5
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
You could always call Jeff and ask him..
Didn't he give you his # when he chipped your car?
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old November 12th, 2007, 13:23   #6
VelvetFoot
VelvetFoot's Avatar
It's all coming back to me now.
I found the coding in Bentley-I thought ECM changeout required a login of some sort but it doesn't (m.y. 2000).
Problem with the 3.1 as I recall is that the ASR light comes on.
Now to see if I can changeout the pins injector harness for the .205's. Always a hassle.
I figure, go for the gusto at 210k miles - if it goes I can justify a new SportWagen (don't tell Mrs. VF)
Of course, it'll probably go another 100k miles. Hey, then there'll be used SportWagens.
Old November 13th, 2007, 19:11   #7
kwong7
Fuel Economy: 48/42/45 MPG
I switched coding from 00001 to 00002 during my lunchbreak. I was under the assumption that I had RC2/RC3 respectively, but 00002 felt like stock...and that wasn't a good feeling. It bogged on the lower throttle and didn't have the kick that 00001 had. It might be that RC3 wasn't programmed in my ECM, but I'll just be happy with RC2. I put it back when I got back to the parking lot.
kwong7 is offline   Reply With Quote
Old November 14th, 2007, 05:37   #8
VelvetFoot
VelvetFoot's Avatar
How do you know which is which? Maybe "1" and "2" are different on yours. As I recall, 3 does have a bigger kick to it.
Of course, injectors really help too.
(I managed to switch out the connector last night, thankfully, and replaced two of the four injectors before "House" came on. Replacing one at a time and starting the motor after each one seems to work very smoothly.)
Old November 14th, 2007, 06:12   #9
jsrmonster
Veteran Member - TDIClub Enthusiast
jsrmonster's Avatar
Hi Karl,
If its vagswitchable, it says the tuning in the header, ie RC s02 or RC s03, etc - look carefully. Sorry not all RC tunings are vagswitchable only euro 110 firmware upgrades. There are so many different TDI archetectures that one answer can't fits all users.
Jeff
15 Golf SW DSG, 00Jetta 6spd race, 99.5Jetta Rocket ARL-PD150 6spd 2260, 2003.5 5.9L Cummins QCLB 4x4 Blue Monster, 00Passat1.8T, other tdi's: 97J, 98J, 99.5J2x, 00-C5 6spd - EFILive, HPTuner, Diablo Sport!
Never argue with an idiot.They will just bring you down to their level and beat you with experience.
The beatings will continue until the morale improves!
Good judgement comes from experience, and experience comes from bad judgement !
"DIESEL TUNING PROFESSIONAL" 1-5-3-6-2-4=;-)
jsrmonster is offline   Reply With Quote
Old November 14th, 2007, 06:37   #10
VelvetFoot
VelvetFoot's Avatar
Will do Jeff.
Thanks much.
Old November 16th, 2007, 06:17   #11
VelvetFoot
VelvetFoot's Avatar
Got everything together the other night. Quite a bit more peppy now. The ECM did need to be introduced to the immob2 cluster via vag com using directions on the ross-tech site.
Page generated in 0.16325 seconds with 10 queries
[Output: 100.17 Kb. compressed to 84.07 Kb. by saving 16.10 Kb. (16.07%)]
