Old July 10th, 2012, 10:24   #1
storx
Default CR140 Big Turbo Build
I decided to start logging the build and kinda debating the info as i go on the build via site instead of through emails so others can benefit from it.
Car:
2009 CR140 Jetta
Mods:
Malone Custom Tune
PDE DPF Delete
EGR LP Delete
EGR HP Delete
3.5" Straight Pipe, downpipe back
Stage 5 SMF Aaron's clutch
R32 Rear Brake Calibers/Rotors
GTB Tubular Manifold
GTB2263VK Small turbo
GT35r Larger turbo (compound setup)
4bar MAP Sensor
CR180 Cylinder Head
Raxle Axles
Audi S3 Intercooler
Sigma 6 Shifter
Resources:
CBEA cylinder head upgrades
EGT/BOOST Gauge
Anti-Surge Idea
GTB2260VK Vacuum Actuator Install
CCV MOD
AUDI S3 INTERCOOLER
*Cleaning up the build... going to put different parts of the build on its own discussions so it not as complicated to read for the next person looking to do a CR build.*
storx is offline   Reply With Quote
Old July 10th, 2012, 10:31   #2
storx
*Moved all turbo pics to correct section under resources...*
Old July 10th, 2012, 12:59   #3
storx
*Under Constructions*
Old July 10th, 2012, 13:04   #4
storx
Old July 10th, 2012, 20:18   #5
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
could you label the pictures?
where are you getting a maifold? Performance Diesel Engineering (Shortysclimbin) and darkside developments (RyanP) have one, or in the works.
the GTB2260VK will be in my future when someone finishes up with the kit. I have the CR180 injectors in hand
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old July 10th, 2012, 20:51   #6
storx
how much the injectors run u? there is a guy malone just tuned with cr140 with gtb2260ck in it and he put down 238whp/448wtq if my memory serves me and he said it still had 12% fuel left.. just needed head work to make anymore power at that point.
Old July 10th, 2012, 22:29   #7
bhutchins
bhutchins's Avatar
$1500 @ boraparts
12% left on fuel pump pressure im assuming? What other mods?
Just got SBC stage 3 and peliquin installed... im ready
Old July 10th, 2012, 23:00   #8
Good Ol' Boy
VeeDubTDI's Avatar
Subscribed.
Old July 11th, 2012, 03:07   #9
ryanp
ryanp's Avatar
I'll reply to your email ASAP! The 65mm wheel wont work well with the stock turbine, i had the first and second prototypes
The head will run out before turbo and fuelling. Obviously you have the CR180 head to try (so do I
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old July 11th, 2012, 04:29   #10
Rub87
Anyone got more info about the block strentgh of the new style engines comapred to 1.9/2.0 style block (as the early CR engines had)
I don't know which block to use..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old July 11th, 2012, 08:20   #11
storx
I am not 100% but i was told on seatcupra site that the commonrail motors have forged rods from the factory that pretty beefy... if someone could clear this up that be nice...
I have sent you a few emails.. been waiting on your replys.. i know your a busy man that is why i not been to worried.. could you please email me about cr180 upgrade and more details on the gtb2265vk setup...
Old July 11th, 2012, 08:21   #12
storx
Originally Posted by bhutchins View Post
$1500 @ boraparts
thats not a bad price.. i was talking to someone about getting a used cr180 head with the factory injectors with it for just a tad more.. but not gotten any replys back in a while so may source elsewhere..
Old July 11th, 2012, 08:27   #13
Rub87
I tought all TDI's had froged rods from the factory..
Rods are not the problem, I want to know which block is the stiffest, please see post: http://forums.tdiclub.com/showpost.p...&postcount=703
Old July 11th, 2012, 12:32   #14
storx
Ya they all go ribbit haha
Had to man...
Da Diesel Build
Old July 11th, 2012, 15:12   #15
ryanp
ryanp's Avatar
Hmm, I suppose if the blocks are weaker the only option is to go BKD/BMN?
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 14:25
CR140 Power: Round One storx TDI Power Enhancements 66 August 23rd, 2014 15:45
Big Build - am I missing something diesel4ever TDI Power Enhancements 39 March 13th, 2013 17:43
Hesitation or Surging CR140 HRC-E.B. TDI 101 2 April 24th, 2012 06:11
Pictures of the CR140, enjoy... bhtooefr General VW Discussion 8 January 28th, 2008 06:57
Page generated in 0.12430 seconds with 13 queries
[Output: 131.02 Kb. compressed to 109.36 Kb. by saving 21.66 Kb. (16.53%)]
