Ol'Rattler,
Thank you for the recommendation. I appreciate it.
Gettyhand,
As for the EGR cooler, the only way the EGR cooler will leak water into the intake manifold is if the heat exchanger core is bad. If that is the case, you can check the cooler by applying a vacuum onto the nipples for the EGR cooler and it should go to maximum Vacuum and hold it all day long. If you show a leak down, it's a bad EGR cooler.
Otherwise, the soot around the EGR cooler is caused by the butterfly valve shaft seal wearing out and allowing a lot of your boost to blow out. This is the normal issue with the EGR coolers, as not many of them leak water.
If the heat exchanger is leaking, there is no good method for fixing them. Normally, we send you a repaired EGR cooler and then you send your old broken EGR cooler back to us. In this case, I have some doubt you have a usable core.
Our kit includes the EGR cooler, several replacement stainless steel gaskets, some with 'legs' that keep them in place, and o-rings.
The dual heater hose, which goes to the EGR cooler is often damaged or swollen. There is a split year for a change on the hoses; 6/06. Please note manufacture date, which can be found on the rocker panel of the driver's door.
We charge $85 for our repaired EGR cooler and offer $85 for a returned core. So, if your core is leaking, the cost of the repaired EGR cooler is $170...roughly 1/3 the cost of a new EGR cooler
The other issue you seem to be having is the puff of black smoke. That is the first indicator of a worn cam/ lifter set. We are well known for our cam kit and it's success.
On the EGR cooler, we offer a life-time replacement. All 4 mounting bolts to the back of the block for the EGR cooler MUST BE INSTALLED, or warranty is void.
The cam kits we sell have a 3 year, unlimited mileage warranty.
Feel free to call or email.
