cumminsfromthecold
I am getting this 65535 error code intermittently.
"Internal Control Module Memory Error"
I wonder if it is related to the occasional flashing red temperature light on the dash. I have just replaced the thermostat and oring, the coolant temperature sensor and oring, coolant T and oring, and of course the coolant. The flashing temp light on the dash, plus the original G 11 blue coolant, was the reason for redoing everything. The car never overheated or leaked or acted weird. But the problem of the flashing red temp light does not appear to be solved.
I have not yet disconnected the battery in an attempt to reset things.
Thoughts?
Thoughts?
