cevans
TDIClub Enthusiast, TDI Parts Ninja Vendor , w/Bus
Our cars are available in Europe and throughout the world with different style suspensions for the different duties they must serve. Two packages that interested me were the "Towing" and the "Heavy Duty" packages. This thread in VWVortex has this very useful chart:
So, with Peter's help we imported some of the "Heavy Duty", 5-green-dots color code rear springs, VW part number 1J0 511 115 AN. According to that VWVortex color code chart, these are a higher spring rate than even the towing package springs.
Last week, I found out that one of my stock rear springs was broken, so I took the opportunity to install the heavy duty springs. I matched them with Koni FSDs, front and rear, keeping the stock front springs (now with over 100k on them).
I am very pleased. Without a load these springs raise the ride height of the vehicle around three-quarters of an inch.
(note how the rise has caused the rear wheel to move backwards slightly due to how the rear beam moves up and down)
I really like the increased ride height. This got me thinking, there are not really many options for "raising" the vehicle. Some have turned to air bags in the springs, or spring inserts in the rear, and the front can use the 12mm strut spacers. The strut spacers give more than the 12mm of raise because, but compressing the spring further, they effectively raise the spring rate. The heavy duty springs are available for the front as well, so I'm looking to get those too.
Shot comparing my "raised" wagon with Peter's "race" wagon:
Alright, so on to the important stuff. These springs are designed for those carrying heavy loads or towing consistently. So, I loaded up the rear of the vehicle with 8 cases of oil. A case of oil weighs around 34 lbs. So, almost 300 pounds of oil, all behind the rear seats. Here is the result:
Today, I loaded the vehicle with 700 pounds of parts.
I took the car for a ride while loaded, and it handled very nicely. Smoother than when unloaded, unsuprisingly, but over speed bumps and dips in the road the suspension performed perfectly.
Here is the result when edit: I think this shipment was over 1,000 pounds is loaded into a wagon with stock springs:
(note mine was packed better, so we could close the door)
So, on the fronts, I think I'm stuck with what I have. The same VWVortex page has this to say for the front springs:
So, it looks like the '03 wagon front springs have two options. 150lb for wagons with the manual transmission, and 170lb for the automatic. I'm hoping to find an automatic set within the next week to complete the set up.
cevans
cevans
