JPuck
- Joined
- Oct 7, 2002
- Location
- San Francisco Bay Area
I just replaced all four sets of brake pads and rotors on my 2002 Golf TDI with around 60k miles, with help from various FAQ's around here. And thanks to everyone because it went perfectly! The rotors even came off without any problems at all.
But while I was replacing the right front brakes, I noticed a rubber bushing on what I think is the tie rod end all squished out and nearly torn out. The picture is below. Does this need to be replaced ASAP? And how hard is this to do?
For the last 20k miles I've been having a kind of crunching sound from the front end when I go over road imperfections at really low speeds (0-20mph). It comes and goes, tends to be more pronounced in warm weather, and happens on any subtle road change... no pothole needed. Also, if it's a day when it's making these sounds, I can get it to "crunch" by applying the brakes at low speed and getting the car to rock forward. It's not related to the brake repairs I just did since the sounds started way so before I replaced them and are still exactly the same with new pads and rotors. 10k miles ago I had the car looked at and supposedly the mechanic couldn't replicate the sound that day and looked at all of the tie rod ends, control arms, etc, and nothing was wrong at the time. Any suggestions? Is it worth compressing my springs and looking at the upper suspension mounts? BTW, the car usually won't make any sounds going over big road surface changes (into parking lots, potholes). Oddly, it pretty much only does it when the car is rocking forward or back in a subtle manner.
