From what i have read in the other post on ABS/ASR, it sounds like this unit (1J0 907 379R)can control a gas engine as well as a TDI. I say this because this option is not available in TDIs. Is this correct?
Birdman,
The part number you gave is for the bottom part only, right? Do you have a number for the top,too?
ETKA is VERY confusing on this subject.
P.S. In the Bentley Manual, they list different Software codes for each configuation. Could it be ASR can be added simply by recoding? Too good to be true.
