garth285
Hey guys well I had my 2012 North American Passat TDI on the dyno last night, was testing out some water/meth injection (No Gain's) so while I was on the dyno I decided I'd like to see if I could make the turbo breathe more if I'd see any results.
What not a better way to make it as free as possible than to just let it open air breathe...
Below is the dyno chart.... as you can see the peak up numbers are exactly the same 118hp/181 ft lbs
The only area it looks like it may have picked up is at 2,000 rpm but it looks like maybe 2hp and 5ft lbs but the dyno operator said that could have just been a error since it was right at the beginning of the run.... none the less.... intakes are generally close to $300 and $100 per hp I dont think it to worth it! So if you have $ burning a hole in your pocket please spend your $ else where if you have a stock TDI!
