shaqtus101
So im somewhat new to these forums, and have done some research and found out there are common problems with cold starts and glow plugs etc. I will be doing some of my own tests thanks to your helpful posts.
Heres the scoop. Bought my 09 TDI in September 2014. Had a check engine light, and the code was PO684. Glow Plug Control Module to PCM Communication Circuit Range/Performance
So no problem. The car always started fine. When it got colder, it would have to crank a little longer, but it would start. Now that its very VERY cold out, its extremely hard to start, and takes a long time of cranking, waiting, cranking, waiting, etc.
Dealer recommended i replace the Control Module. No problem. All it was was a glorified relay, that was placed under the battery, so I did it. Still had an issue with it and took it to the dealer, and he fixed it and said it just wasnt plugged in completely all the way. (It was very cold outside and snowing and a tight spot so i did all i could to hear it click in, in which i never heard the click in)
Problem persisted though, so i paid VW 3 hours diag time and they checked all the wiring and ground points and saw all of that was good. They said it was probably a ECM problem and that it would be $2100 to replace. But with a discount they could do it for $1600.
So again, the car starts in the warmer weather no problem. When its cold, it takes alot of extra time. So any input on what to do next? Pretty pissed about this. Ill have to take the corvette out of the garage and drive it until it gets a little warmer out. UGH!!
