HELP! 2006 New Beetle TDI won't start in park!
smilingngeorgia
Georgia
2006 New Beetle TDI
After a 75k basic service, my TDI wouldn't fire in park; when you turn the key, the engine turns over but there is no firing. I had it towed immediately and after a diagnostic check, this was deemed a fluke. Car started up perfectly after sitting in the shop for 3 days. Since this initial 'fluke' this has happened on 5 additional occasions. I have taken it to two additional garages (one being a VW dealer) and no one has a clue what to do. Finally, yesterday when the nonstarting occured, a stranger told me to try to start it in neutral rather than park. Lo and behold, it started! What is up with this???
ST1300A
Oceanside, CA
2006 New Beetle DSG PKG 1
I would suspect a bad or misadjusted neutral "safety" switch.
Service intervals on your Bug are every 10,000 miles, regardless what the dealer says. :rolleyes:
You should start saving now, the 80,000 mile service is the timing belt change :eek: - DO NOT take it to a dealer for this (or preferably any other service), find a Guru in your area instead...you can thank me later... :D
Bob_Fout
Oil Wanker
Indiana
2003 Jetta - Alaska Green (sold) / 2015 GTI 2.0T
The timing belt is at 100K miles. Inspection is at 80K miles.
smilingngeorgia
Georgia
2006 New Beetle TDI
thank you
Thanks for the guru list...that will be helpful! We thought we had the problem solved...changed the fuel filter and got a new battery. It started perfectly for 25 tries then poof...right back to the nonstarts! ARGH
ST1300A
Oceanside, CA
Bob,
For no reason the dealer or VWOA could give me, the official replacement interval on the 2006 New Beetle is 80K (there is no inspection interval listed). In 2005 it was 80K inspection, 100K replace. Doesn't make sense to me, but that IS the schedule.
Weird, huh!!!
Bob_Fout
Oil Wanker
Indiana
What does your owner's manual say about it? 80K or 100K miles? The linked document from VW shows 100K miles.
My guess is your dealer is doing like most dealers and fishes for money.
ST1300A
Oceanside, CA
Bob,
In the linked document, page 25 of 29 states 80K miles for timing belt replacement on the 1.9 liter TDI. So does the maintenance schedule on the VW web site, and the owners manual I have from my '06 says the same thing.
It is weird how just a year older car would go to 100K - maybe they were getting an unacceptable number of failures at that mileage?
Bob_Fout
Oil Wanker
Indiana
Jees, I really misread the service schedule :eek:. I have no idea what I was looking at on it that I thought was the TB. Sorry!
