stevieturbo
Diesel newbie here....and not a modern tdi...hope this is ok ??
1993 2.4 straight 6 volvo 940td VAG engine. T3, intercooler, mechanical pump.
This car is an auto, and as such, feels laggy. Boost response/spool is usually quite poor.
So, I fitted a T3 with a smaller 0.25 turbine housing. Doesnt really feel much better. Same compressor. ( kickdown also adjusted so it rarely kicks down, so I can use a decent amount of throttle )
At 10psi, EGT's did get as high as 600degC measured before the turbo.
I try 20psi...EGT's rarely go above 500degC !!! ( Innovate TC-4 )
Ive tried screwing the diahpram on the pump, but it really makes no difference. Can these sieze up inside ? Regardless of how far I adjust it, the car never smokes.
I also have the EGR blocked off.
Any thoughts....or should I just leave it alone, as its sad trying to mess with a diesel automatic volvo !! lol
Basically I just want to try and improve low end torque, as I rarely venture above 3000rpm.
Or is it worth trying to adjust pump timing ? car is noisy...as these are, but runs fine. What effect would pump timing have on EGT's ?
Cheers, Stevie
Cheers, Stevie
