Hello,
So I wanted to make topic about my next project car which target is 400hp on diesel only.
Car had 2.5TDI V6 engine, but that engine will be changed to 1.9TDI engine.
Modifications what is planed to do, to reach this target:
Ported Head
Lighter valves
10mm lift camshaft
Hard valve lifters
Head studs
PD intake manifold
Stock PD130 bottom end
Deeper valve pockets in pistons
New piston rings
Turbo BW S356V
Tubular manifold
11mm Fuel pump
0.330-0.370mm nozzles, depending on which size will be to short
FMIC
63mm IC Piping
76mm Exhaust
And some pictures(If someone has problem to see them, tell me)
Got 1.9SDI engine, for good head without cracks and other parts what will be needed.
Then luckily found turbo to reach 400hp
Then got 1.9TDI PD130 engine
Ported head
Lighter valves
Assambled engine bottom
Hard valve lifters
For now so far with engine, now need to be get done many water pipes by hand, set wcu and wiring, find place for turbo and start to make tubular manifold.
Ported Head
Lighter valves
10mm lift camshaft
Hard valve lifters
Head studs
PD intake manifold
New piston rings
Turbo BW S356V
Tubular manifold
11mm Fuel pump
FMIC
63mm IC Piping
76mm Exhaust
Ported head
Lighter valves
Hard valve lifters
