Old July 2nd, 2020, 14:25   #16
avcentraltias
Nope, just ordinary pump diesel.... the blue smoke I saw might be due to the WD40 I sprayed into the IP to lube it while it was bleeding from bone dry....
I’m going to ask my mate to come and time it with the proper kit once these injectors are back... then there should be no excuses for smokiness...
avcentraltias is offline   Reply With Quote
Old July 2nd, 2020, 15:35   #17
Mongler98
once your injectors are spraying properly, you won't have any blue smoke issues. you can easily hammer mod your way to close enough to drive it. also you cant get the timing set properly as everything within VCDS requires it to be running and to operating temperature first. you have some time.
Old July 4th, 2020, 14:47   #18
avcentraltias
sorted now! ��
Blue smoke gone, white smoke gone, no smoke to be concerned about at all now.
The old girl seems to be running great with new nozzles....
Glad I asked here, thanks ��
Old July 4th, 2020, 17:21   #19
Mongler98
told yea!
lesson learned here, when storing your injectors, put then into a glas jar with diesel submerging the entire nozzle.
if they are stored on an engine that has fuel in the IP and ran when last shut down, they are usually fine with a once over with a cleaner in the fuel system.
Injector Pump seals / problems / wont start snagster VW MKIII-A3/B4 TDIs 14 July 6th, 2014 16:49
Tdi buzzing from Injector pump, wont start, low power when it does dubrat720 VW MKIII-A3/B4 TDIs 8 January 13th, 2013 02:20
1Z/AHU Valve Cover, Injector Lines, Longitudinal Steel Oil Pan (B5 AHU/1Z/AFN/AHH) G60ING Private TDI Items for Sale/Wanted 0 January 11th, 2013 08:00
ALH wont start after tb change need injector pump help indysoto TDI 101 3 August 9th, 2006 08:58
Car wont start (replaced fuel injector pump) festivenuts VW MKIV-A4 TDIs (VE and PD) 18 May 14th, 2006 15:01
Page generated in 0.15265 seconds with 12 queries
[Output: 63.28 Kb. compressed to 56.90 Kb. by saving 6.38 Kb. (10.08%)]
