Fullhouse
Hi there !
I hope somebody can help me out here .
First things first: 1 month ago my PD injectors were taken out and cleaned in an ultrasonic bath.
With new seals the PD injectors were adjusted, because after my stud broke down from my tensioner (timing belt) they mounted a new head on the engine but the adjustment of the PD injectors weren't correct.
I felt it because I had loss of power and when I hit the brakes it felt as if my brakediscs were crooked.
So after a good adjustment and new seals the car cranked and started normally.
But few days later the car started more difficult (the crank was good though).
It took about 5 seconds to fire up the engine.
This problem lasted for one week, untill I fueled up the tank. After that the car would not start.
So I pulled my key out and turned it back on again and the engine fired immediately.
I have replaced my fuel filter (2 months ago) with new seals and the T valve on the filter.
I have checked the liftpump in the tank. I pulled out a fuel hose and turned the key on and diesel was coming out.
I also checked the coolant sensor (pulled the plug) but when I did that, the engine started later as usual.
I also replaced the 109 relay last week and I thought my problems were solved, but unfortunately today my engine would not start after I came home from my job.
The car cranked but no start, So I pulled the key out and turned it back on, the engine fired immediately.
It seems like when the engine is cold, the engine starts immediately but when the engine is hot, sometimes the engine would not fire.
I really dont know what the problem is.
