VincenzaV
Hi, I have a 221K mile original 2004 BEW Jetta turbo that is slowly leaking oil and I "brought back to life" temporary by articulating the smart actuator several times, seemingly freeing up the vanes. I now have some boost, but feel a turbo replacement is in my not-to-distant future.
I want to upgrade to the VNT17, will do exhaust, nozzles, a tune, the whole shebang at once. The problem being is my EGR (and presumably intake) is cartooned up bad! It's drivable, but definitely lacking power cause there is maybe a quarter or so opening for. the air to pass through.
I can't clean my intake, or I'd do that (I live in one of those apartments that looks down on working on your car and using a blow torch and compressor to burn it out).
So it looks like my options are:
1. Drive it like this for another few months till I am in a rental house (and a garage again-Yeah!)
2. Install a cleaned PD100 stock intake (with install kit obviously)
3. Install a PD150 intake with Darksides kit to retain the EGR/ASV. This will get me through the upcoming vehicle inspection (No EGR code for deleting).
Option #3, I can choose to delete the EGR/EGR cooler later if I decide AFTER I get the VNT17 and Tune to eliminate the EGR light.
It's important for me to keep the ASV, even after the tune. Some don't care, however I do.
At what point is the PD150's improved flow THAT noticeable over the PD100's (On a tuned motor....)? Is it worth it if I go VNT17, Tune (stage 4 likely), nozzles, billet cam-like I plan in the future?
I really want to fix this clogged up intake now, without having to buy two different intakes in the period of a year or to. Again, if my intake comes off-I can't clean it here in the complex via blowtorch. I can swap it out with another, on a weekend when the office isn't here, but my neighbors will dime me out or call the fire department if they think I'm burning down their precious place..lol
Thanks!
Thanks!
