lilredwagon
First post in a long time. I searched but was unsuccessful in finding anything related to my specific issue.
Here goes:
Last Wednesday we had torrential rains. Wife reported that her GSW started leaking water onto her feet in the drivers side footwell, and that water was coming through the forward interior light fixture.
Next day she gets an MIL/CEL. I scan and it's P148b. Go online and find this 'technical tip from VW': 26-18-04TT
https://static.nhtsa.gov/odi/tsbs/2019/MC-10163514-0001.pdf
It says that water running down the drivers side A-Pillar from the leaking sunroof drain has caused corrosion on the "TUIL" Connector. That corrosion is causing a short and thus the MIL. And that you have to clean or 'repin' the connector as well as reset the Selective Catalytic Reduction system. I don't have the VAGCOM software so that's another issue.
Problem: The car 'thinks' it's out of DEF and it threatening me with not starting within 600 miles. However the DEF tank is topped off and the car runs just fine.
My question is: what's the most economical way to solve this problem? I know about the Rawtek/Malone $2k solution but that's not in my budget.
[ETA: I cleaned out the sunroof drains and the front left was clogged. I removed all 4 nipples from the ends of the hoses and will now commence cleaning regularly.]
I'm considering a software solution or disassembling the interior to get at the corroded connector. Problem is I can't find anything about a "TIUL Connector" anywhere.
I assume that it's part of the DEF system.
Why put an unsealed connector right next to a sunroof drain line that is known to leak? On an otherwise well engineered and excellent car?
At least put some heatshrink or electrical tape around it since the car can't run if it loses connection ffs.
I appreciate any insight the gurus here could provide on this issue.
My next VW (a GTI) will not have a sunroof.
Here goes:
