This is a question which I posted on another VW forum and did not get a final answer. Maybe here I will:
The 4 cylinder VW diesel engine camshaft sprocket according to my Haynes manual may or may not need a woodruff key. My camshaft sprocket end has a keyway and I assumed that a woodruff key was needed. I heard however from another forum that a key should not be there. My question is this: why would VW engineers cut a keyway in the tapered end of the camshaft is a woodruff key was not intended.
Thanks.
Haybayian.
Thanks.
Haybayian.
