Old June 12th, 2019, 12:54   #1
beechfront
TDI(s): mk7 golf
Default Road Trip Tools
Planning to put about 8,000 miles on my mk7 TDI over the next few weeks into some pretty remote areas.
Fairly new to VW diesels and wondering if there is anything I might want to bring along for simple roadside repairs?
Thanks in advance.
beechfront is offline   Reply With Quote
Old June 12th, 2019, 13:01   #2
Lightflyer1
Lightflyer1's Avatar
AAA card and credit card. Other than the tire tools and jack there really isn't much simple to work on. Some basic hand tools maybe. An OBDII dongle and the Torque app. if you don't have VCDS.
Old June 12th, 2019, 13:16   #3
beechfront
TDI(s): mk7 golf
Kinda my thoughts as well. I do have an OBD11. Gonna bring an extra fuel filter, tire pump, plugs, etc.
I was also happy to find a full size spare easily fits where the donut was located.
Old June 12th, 2019, 13:39   #4
Lightflyer1
I would skip the tire pump and plugs and just bring one or two of those fix a flat aerosol cans. They work in a pinch. Unless you are buying fuel from some really crappy place I wouldn't even bring the fuel filter. You should have at least 600 mile range. Fuel up at good places in populated areas.
Old June 12th, 2019, 13:44   #5
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
What PLUGS are you talking about ???
Just my opinion, but a fuel filter isn't necessary.
Walmart sells a tiny top up compressor for about 15.00 and it fits in the glove compartment. It's made by SLIME !
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old June 12th, 2019, 14:03   #6
beechfront
TDI(s): mk7 golf
Tire plugs, haha. I've had good luck with them in the past. Personal preference but I'd take them over the fix-a-flat cans.
Good point with 600miles range I should be able to skip any shady looking stations and fill up only at "good places".
thanks for replies.
Old June 13th, 2019, 09:15   #7
andreigbs
I second (or is it third?) skipping the extra fuel filter. The one you have one should be fine, assuming you've been on top of maintenance.
I, too, prefer the tire plugs and a good portable compressor over fix-a-flat cans.
I would probably want to have a liter of topping off oil, just in case. I'd also make sure my wipers are in good condition. Nothing like a roadtrip with rain and crappy wipers.
2014 Jetta TDI // 28xxx miles // 39 MPG & 2014 GLK 250 // 98xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old June 13th, 2019, 09:40   #8
Lightflyer1
I have had a portable compressor for over 2 decades and carried it. Never had a use for it and it sits unused in its case to this day. I am not a fan of fix a flat cans either but they have their place, which is to get me to a place who can do a professional job of patching or replacing the tire. You do have a spare so unless you get 2 flats in close proximity of each other you should have no need of them either. Just an easy backup if needed and quick. Getting the car in shape before leaving goes a long way towards not needing anything en-route. If your oil is full when you start and you are a quart low during your trip, you have other issues that need to be addressed. I do wipers once a year.
Really unless you are heading into the the wilds of Alaska, Canada or Mexico you shouldn't have any need of anything if your car is in good repair "before" you leave. A cell phone, AAA and your DL and a credit card with regular checks when you fuel should do it. Or you can load up all kinds of tools and support parts like you were competing in the Baja 500. They will all just be in your way, add weight and reduce your capacity for other things you may actually need and/or use.
Old June 13th, 2019, 10:58   #9
Jetta_Pilot
My preference to fix a flat, is let a professional do it.
But if necessary I carry one of those kits that has a rasp for the hole, another tool looks like a hook. Also some stringy things and a type of rubber cement. This lets you fix a tire even without removing it.
Haven't needed that in many years though.
Unless I'm wrong you have to remove the tire from the rim for a plug?
Old June 13th, 2019, 11:38   #10
Lightflyer1
I am a customer of Discount tire. They have always fixed my leaks professionally and for free and quickly. I am a big fan of them as they have good quick service. I will always try and get to a place like this to have the repair done. With a spare and a can of fix a flat you should be able to get to a place. A proper repair involves removing the tire and putting a patch on from the inside.
https://www.youtube.com/watch?v=iPRUdaxXgVw
Old June 13th, 2019, 14:40   #11
tactdi
tactdi's Avatar
TDI(s): 2005.5 Jetta
AAA and a credit card is fine is you have the time to wait. Same goes for having run-flat tires on your car (discussion for another time).
I have needed AAA to tow me off of I95 outside of Savannah one Friday afternoon. Luckly the driver towed me to a NAPA where I could buy a coil to replace the one on my Jeep that crapped out. If not, I would have been towed to the Jeep dealer, and it would have been Saturday morning before I would have gotten back on the road (at the earliest).
Back to TDI content, in my Jetta, I had a flat outside of Lafayatte, IN, one Sunday night in the rain. Luckly I had a full size spare, instead of a donut. My buddy had to be at a conference Monday evening in VA, which we where planning to drive to starting Monday morning. If we had a donut or runflats, it would have been late Monday morning at the earliest before we would have gotten on the road (having to find a tire dealer), and would have gotten to the conference in the late evening.
tactdi is online now   Reply With Quote
Old June 13th, 2019, 18:54   #12
Lightflyer1
Beachfront said he has a full size spare. Hence the fix a flat just for an emergency after that. If you use the spare stop and have the flat fixed. Shouldn't take but an hour at the most I would imagine. Never in my lifetime have I ever had 2 flats anywhere near each other, time frame wise. Any time I have needed a tow I have had to wait, no matter who it was. Someone I called or AAA or Hagerty or any other. But if you are broke down and need a tow, you need a tow. They will tow you where ever you want within reason, be it parts store or dealer or home.
Old June 14th, 2019, 12:27   #13
beechfront
TDI(s): mk7 golf
plugs can be easily done with wheel still on the car.
normally I would be perfectly fine with only donut spare. this is portion of road I am somewhat worried about.
https://www.themilepost.com/highways/dempster-highway/
Dempster Highway
Connects: Klondike Highway to Inuvik, NWT
Route#: Yukon Highway 5, NWT Highway 8
Length: 456 miles
Road Surface: Gravel
Season: Open all year
Highest Pass: North Fork Pass Summit, elev. 4,229 feet/1,289m
Map (1 detailed pdf file available):
Klondike Highway Junction to Inuvik, Northwest Territories
The Dempster Highway begins about 25 miles/40 km east of Dawson City, YT, at its junction with the Klondike Highway, and ends at Inuvik, NWT. Facilities are few and far between. It is strongly recommended that motorists carry a full-sized spare tire (or 2 spare tires if they are an unusual size) as well as extra water and gas.
Old June 14th, 2019, 13:00   #14
Lightflyer1
I forgot that was where you were going. I would add another full size spare and the plugs and a compressor. some survival gear might not be bad either. Maybe rent a sat phone for the trip just in case. Are you guys allowed to be armed up there? When I was in Alaska long ago it was the rule to never go anywhere without being armed, when not in town.
Old June 14th, 2019, 13:39   #15
Owain@malonetuning
Sounds like one heck of a trip! Definitely worth bringing a fuel filter and a 20L jerry can in case of a bad tank of fuel, along with at least 1 full size spare, accessory belt, and oil pan or install a skid plate. Might consider slightly oversized tires as well for some ground clearance.
Wouldn't expect much in the way of phone, vehicle service, or AAA north of grand prairie, it's truck and snowmobile territory. Will be hundreds of miles between small towns where most haven't seen a mk7 tdi. NWT has 6 villages over 1000 people, the Yukon has two, in an area about triple the size of texas. Prepare accordingly and bring a lot of sealed rations (less smell). Get as much info as you can from local truckers.
Owain@malonetuning is online now   Reply With Quote
HELP 2/8/15 Limp mode, Vegas road trip, P1557 dusty dirt road HELP! mattpetty VW MKIV-A4 TDIs (VE and PD) 5 February 8th, 2015 15:03
First road trip alien VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 January 4th, 2010 16:13
A little off-road pit stop during my past road trip....FULLY LOADED with a boat!!PICS Keven Road Trips 13 May 21st, 2009 20:48
Road America Road Trip! (A TDIClub GTG) Matt-98AHU TDI Motorsports 21 August 18th, 2006 21:35
Page generated in 0.19547 seconds with 13 queries
[Output: 127.23 Kb. compressed to 105.74 Kb. by saving 21.49 Kb. (16.89%)]
