Old June 12th, 2019, 10:01   #1
nathanso
nathanso's Avatar
Default Resistance shifting into 1st gear
At random times, my 2015 GSW TDI S 6M will not shift into first gear without considerable resistance. This is, of course, from a dead stop; usually after waiting at a red light. Trany is fully warm; clutch is fully depressed.
The car has 55K miles and has been mine since 53K. Still under CPO warranty but since the problem is so intermittent I'm loath to bring it to a dealer for service lest it be a complete waste of time.
I've seen this topic arise on other Mk7 forums with no solution. I was considering changing the trany oil to Redline or Motul as doing so on past cars has lightened up shifting and mitigated snychro issues somewhat.
Can anyone provide any insight here?
nathanso is offline   Reply With Quote
Old June 12th, 2019, 10:17   #2
ProfBrown
Fuel Economy: In the sig
I had an older BMW manual 328i and it would do the same thing from time to time. Actually every manual I have driven has done this (both cars and VW powered/trans sand rails/dune buggies). What I understand it to be is that at certain time stoping the gears will be aligned in such a way that they do not perfectly mesh. To remedy this you can rock the car back and forth in another gear, or simply shift it into another gear before trying 1st again. This on the past has always been the trick. Even dirt bikes do the same thing in my experience.
If that makes sense lol
2015 GSW TDI SE DSG
DON'T TRACK THIS ANYMORE
ProfBrown is offline   Reply With Quote
Old June 12th, 2019, 12:19   #3
sootchucker
sootchucker's Avatar
TDI(s): 2015 Golf
Fuel Economy: Good
i have this problem occasionally as well. not sure why, or what to do about it. sometimes i feel like first gear is not an option.
Who says a Jetta can't roll coal???
sootchucker is offline   Reply With Quote
Old June 12th, 2019, 13:30   #4
mkane
TDI(s): GSW SEL 6spd
Every manual vehicle ever owned I always go to 2nd before reverse or first. Always.
mkane is offline   Reply With Quote
Old June 12th, 2019, 15:12   #5
Jasper J
Jasper J's Avatar
I occasionally experience this as well in my 2015 Beetle. Feels more like some kind of mechanical blockage in the shift gate than the synchros.
2015 Toffee Brown Convertible Beetle 6M (Toffifay)
Bought Back: 2010 Candy White Golf 6M
Replaced: 2010 White Gold Jetta Sedan 6M
Replaced: 2003 Reflex Silver Jetta Sedan 01M
Jasper J is offline   Reply With Quote
Old June 13th, 2019, 12:05   #6
nathanso
nathanso's Avatar
Agreed!
Old June 14th, 2019, 07:00   #7
GeneralHaberdashery
I've noticed this on mine. There's a bit of resistance going into first, if I let off a bit and try again it pops right into gear. I also test drove a Passat 6MT that did something similar. May just be a VW quirk?
GeneralHaberdashery is offline   Reply With Quote
Old June 14th, 2019, 07:02   #8
ProfBrown
I think itís an every day consumer manual car kinda thing not just VW. My bmw did the same, every manau car Iíve ever driven has, and so have dirt bikes and quads.
2015 GSW TDI SE DSG
Old June 14th, 2019, 08:04   #9
mkane
^^^^^^^^^^^^^^^^this. How long have some of you folks been driving?
Old June 14th, 2019, 17:21   #10
Miss_Athanatos
Miss_Athanatos's Avatar
^^^ This.
Never had a problem shifting into first.
To the OP: Do you sit at intersections in neutral?
Hope my posts make you smile.
2015 VW Golf SportWagen TDI S, 6-speed manual
2016 3500 Ram Tradesman 6.7L Cummins, 6-speed manual
Miss_Athanatos is offline   Reply With Quote
Old June 15th, 2019, 08:49   #11
nathanso
nathanso's Avatar
Originally Posted by Miss_Athanatos View Post
^^^ This.
Always in neutral, clutch out. Friends don't let friends needlessly wear throw-out bearings or front crankshaft bearings! It could be my inexperience with driving and clutches in general.. only 40 years and 15 or so three-pedal cars.
The good folks at Dieselgeek just suggested that I check the linkage for proper adjustment as it may have been bollixed during some past service.
Grinding when shifting into 1st gear. Sublime69 TDI 101 6 November 7th, 2012 06:25
Shifting into 1st gear; clutch issue? joe4str TDI 101 19 June 3rd, 2011 19:01
Difficulty shifting into 1st gear. Vinyl_Addict TDI 101 7 March 28th, 2007 12:32
Changing gear oil can help shifting easier in the 1st gear? Andrei Rinea VW MKIV-A4 TDIs (VE and PD) 1 December 2nd, 2002 11:18
Problems shifting into 1st gear TDI Golfer General VW Discussion 8 April 29th, 2002 09:59
Page generated in 0.16178 seconds with 13 queries
[Output: 103.31 Kb. compressed to 87.50 Kb. by saving 15.81 Kb. (15.30%)]
