Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 11th, 2019, 09:12   #1
DayMan8404
Default Clock and maintenance reset button not working
My clock is 7 minutes fast, so not the worst thing in the world, but the button that changes and rests it isnít working. Wondering if maybe itís fuse issue or if I need to pull the dash apart to figure it out.
DayMan8404 is offline   Reply With Quote
Old June 13th, 2019, 09:24   #2
andreigbs
Hold on a sec, can you go through the steps you're taking to try and reset it first?
2014 Jetta TDI // 28xxx miles // 39 MPG & 2014 GLK 250 // 98xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old June 14th, 2019, 04:52   #3
DayMan8404
Push button with clock symbol, highlight what I want to change (minutes), push 0.0/SET button, nothing happens.
Old June 14th, 2019, 06:25   #4
andreigbs
OK, so the right button on instrument cluster isn't working to change minutes.
Have you tried changing the hour? What about being able to switch between odo and trip meter?
Old June 14th, 2019, 14:10   #5
DayMan8404
I can switch between everything. It wonít change the time or reset the maintenance. It does nothing.
Clock and Trip Reset ARCJr VW MKIV-A4 TDIs (VE and PD) 10 August 23rd, 2016 10:01
tripmeter and clock reset vandep32 VW MKV-A5 Golf/Jettas 7 November 26th, 2011 08:12
how to reset dash clock? ILowNslowI VW MKV-A5 Golf/Jettas 15 April 12th, 2011 13:00
Clock and Trip Odometer reset. gebbeth VW MKIV-A4 TDIs (VE and PD) 1 November 9th, 2008 07:58
B4 - Clock and Odometer getting reset blkbeetle TDI 101 2 February 4th, 2002 09:04
Page generated in 0.15867 seconds with 13 queries
[Output: 68.23 Kb. compressed to 60.44 Kb. by saving 7.79 Kb. (11.41%)]
