gw51ftc
Hi, I just purchased a 2003 Jetta wagon (5-speed manual) that I hope turns out to be a good buy. Previous owned did timing belt and clutch and other work but I guess changed his mind about it when replacing the sensor (varistor) in the injection pump did not fix the issue. I need some details on the wiring between the sensor and the ECU. Is one end of the sensor ground and it is just a one wire connection measuring voltage drop or two wires? A pin out of the plugs involved would be nice. I know am a asking for a lot. I've looked for electrical diagrams on line with no luck. Thanks in advance for any help.
Gary
Gary
