Rear spring perch bedding?
300D
New England
Mk6
Just swapped out my rear springs. Spring perch looked a bit crusty. This popped off:
Some sort of metal paste bedding?
Is it needed? None of the stuff I have found to read about rear springs mentions anything about the bottom of the spring being bedded in anything. I reinstalled it without the crusty bedding:
300D
New England
Mk6
macoombi
Ottawa, Ontario, Canada
'02 Jetta TDI
I installed a new axle beam this spring and realized that I forgot to swap those things from the old one (or to install new ones - probably a smarter idea). I haven't noticed any problems without them installed.
JETaah
mi 48836
96 B4V, 1999.5 jettaIV,2005 BEW Beetle
It is there as a sacrificial interface between the spring and perch. Made of zinc.
