Oil pan bolts
PickleRick
Greenville sc
05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
Cats suck. Cats knock over tub holding oil pan bolts and front flange bolts. What are the dimensions of 2 rear seal flange bolts? The 2 bolts that go through the pan into the rear flange
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2011 Tiguan TDI/DSG 2005 Audi A4 Avant 6MQ TDI 2011 BMW X5 35d
All 18 or 19 oil pan bolts are the same
PickleRick
Greenville sc
Thank you. I thought the two on the very rear were shorter. Im currently reassembling everything. Fingers crossed all i lost was the clutch line clip.
JETaah
Vendor , w/Business number
mi 48836
96 B4V, 1999.5 jettaIV,2005 BEW Beetle
Did you wind up with two shorter bolts?
If you do, that is where I would put them...in the middle two rear seal holes.
It may be a non-issue on the BHW but it makes it easier on the ALHs where you have to angle the tool a bit to place them.
PickleRick
Greenville sc
I have lots of exta bolts. I have a few tubs on a rack from where I've parted out or am parting out some passats and they were kocked over.
