iamatt
Hi guys have a 2014 jetta tdi. The AC is intermittent but when it blows it blows cold. Where is the AC pressure switch located so I can try jumping it? Other than that open to any other troubleshooting ideas. Thanks!
Yes, see post #2. Of course, watching data in the Climate module is only useful if the system is for sure charged, but refrigerant leaks are pretty rare on these cars. RCVs, on the other hand, are VERY common.This is the same as the solenoid on the compressor? Assuming you are referring to RCV ro the control valve? Aw no more jump testing or hot wiring these guys. I was born 75 years too late. Any way to test the valve Oilhammer?
