ChewMT
I finished my timing belt swap and found I was now in limp mode. The source of the issue was I forgot to re-connect the pipe to the turbo.
I re-connected the pipe to the turbo but I'm still in limp mode. I've checked the following things:
My timing is good as verified by Vag Com.
I tried disconnecting my battery.
Cleared all fault codes even though it said there were none.
I'm now at a loss. Hopefully someone here can help me out. Keep in mind I'm still a novice with Vag Com.
