Missing lower engine cover
brownnugen
Charleston, SC
2015 GSW TDI, 2011 JSW TDI & 2018 Atlas 2.0T S
I just picked up a 2006 Jetta TDI and it is missing the bottom engine cover that keeps a lot of road debris out of the engine compartment. Is this a TDI specific part or is one from a gasser compatible?
Matt Carlson
AZ
13 Golf TDI
I just got the mk5 r32 belly pan and it fits perfect.
It is also a lot cheaper than oem.
relumalutan
Michigan
06 Jetta TDI Special Edition
Since you're at it, might as well install in addition a Dieselgeek Panzer plate, as the OEM plastic ones will not do much against rocks that have the potential to kill your oil pan.
