alongjordan
Hello all and thanks in advance for your feedback or assistance on this.
I have searched the forums here and on the net at large for information on this particular issue. Some close, but just not quite...
So, I have a 2001 Jetta with 01M transmission, engine and transmission from a similar year Beetle (was told this by the seller when I bought the car, anyway to look up engine/transmission numbers?). When I connect my Foxwell code reader with VAG module. I can see my ECM, air bags, instruments, ABS... as far as I can tell, everything that the car should have -except- the TCM.
When I was attempting to diagnose things earlier this year, I found that I had a bad battery (I could read the TCM with a battery charger on the car, could not read it without).
I have since replaced the battery and still cannot read the TCM.
I am hoping to go through the connections and grounds near the ECM and TCM under the cowl. I hope that this will let me know if I have a faulty TCM or something else going on.
Would I appear to be going in the right direction here?
If it looks like I need to replace the TCM, what are my best options once I have a part number directly from the unit in the car?
Thanks again in advance.
