Shorter throw means you're multiplying the fork travel vs cabin travel.
It's forcing the synchro quicker, harder because of the shorter throw.
All comes down to leverage. JFettig is correct.
Also, the talk of type of flywheel destroying synchros is bull**** in my opinion. I might be wrong, but it's my opinion.
Single Mass, dual mass, triple mass, no mass, a fat ass, cardboard flywheel, golden flywheel blah blah blah... .
If your slave, fingers, and pressure plate are functioning correctly, the input and disc should fully separate from the flywheel, having no engine harmonics or torque transfered to it, THEN synchro engagement needs to begin and fully complete, locking the output and input shaft (with the disk) , before releasing the plate, transmitting torque and harmonics... ....
If there's any flywheel and disk drag, while that poor brittle synchro is trying to match the input shaft speed to the output shaft, any violent pulses are going to raise hell with it. Point blank. No argument.
Once in gear synchros do nothing. Fully out of gear, synchros do nothing. They just float on the shaft without any side or thrust pressure.
Dog teeth and over center snaps are what keeps things in gear. I've never had a vw gearbox apart, yet, but everything else I've had apart are like that.
I'd gamble improper disk release, or drivers with lazy legs.
Combining a short throw and not adjusting your foot timing, with the possibility of not having a full mechanical release, obviously is a failure waiting to happen. I will agree with a single mass it'll be much much more violent if there is any transmitted pulses/torque to the synchros, since there's no Springs for squishy cushion.
At one point they did make gearboxes without synchros. If you have driven one, you will appreciate the world of difference synchros make. Especially a gearbox with thick gooey 90w.
Sent from my One using Tapatalk
